hi there all
i have been playing with a Xeox 1250 that has the oil in it as part of the fuser?
the gloss and finish from this printer is fantastic, although slightly outdated, what i was wondering is what other copiers are out there that have the oil consumables in them, i know that there is the 1256 as the new model what i was wondering is who else makes a similar print system, also has a well located print, as i have a xerox docucenter ii c 3300 that once you use thicker card (250gsm and above) the image can wonder around the page by around 3-5 mm.
any advice or ideas would be great, what i would like to do is use it for printing on 300Gsm stock for business cards, hence the minimum of movement in the image as well
thanks
carneage
thanks
carneage
