WorkCentre 7665 "Replace Corotron" message
  • Ajaxfan77
    • Sep 2009
    • 47
    [Electrical] WorkCentre 7665 "Replace Corotron" message
    Hi
    Can anyone help to clear message "Replace Corotron" in WorkCentre 7665, i tried several corotrons, new black drum. I reseted CRU in WCPP Diagnostics (former was 5 % and its also now), after reseting to 100% when machine booted up the problem came back... Original corotroh (which was in machine) has CHIP!!! Other ones (even supplied with new drum) don't have chip. Numbers of all corotrons are the same - 13R630
    Thanks for any help
  • bojans
    • 1313
    Did you try to reset NVM IOT/Finisher - 1881 (Chain link 751-449) to 0 ?
    • adriansto
      • 2384
      You can use a 60 mA fuse for reset
      Upgrade firmware level of copier so when you put in a new drum make reset even at scorotron.
      • Ajaxfan77
        • Sep 2009
        • 47
        Re: WorkCentre 7665 "Replace Corotron" message
        Thanks guys,
        First I've changed tresholds for corotron (751-449 didn't work by me) later rested with fuse
        Thanks for help
        PS. By the way what is the highest level of SW for this machine??
        • Caffeine
          • 391
          The current highest is 040.033.53230, released on June 10th, 2011. (For the 033 series, anyway. I have no idea about the older 032 series.)
          • Ianizer
            • Jul 2011
            • 380
            (If you're still at .032, I'd suggest updating.)
            I've had WC HFSIs take a l - o - n - g time to reset. Really. Especially, fusers.
            Others reset right away. Weird.
            Looks like you have a fix though.
            -I
            My name Peggy.
            You got problem?
