Xerox workcenter pro 275
  • azehnali
    • Nov 2009
    • 679
    does anyone know how to change a non metered 275 to a metered
    it is using 113R674 cartridge and I want to use the 113R672
  • bojans
    • 1313
    I believe you should change service plan.
    • adriansto
      • 2387
      Why you need that ?
      • Guest
        Re: Xerox workcenter pro 275
        changes in the service plan is likely to be replaced drum
        • amadeusmbi
          • 51
          - 113R00674 - Sold (US)
          - 113R00673 - Sold (XE)
          - 113R00672 - Metered
          Service Plan Type
          A - Sold
          B - Meter
          To Change the Service Plan Type
          *Obtain the machine serial number.
          *Enter the Service Plan window in Tools Mode
          Enter Tools Mode:
          1.Press the Access A button, (XE has a KEY ICON) and enter the password i.e. (1111).
          2.Select: Go To Tools.
          3.Select: More.
          4.Select: Consumable Management.
          5.Select: Service Plan.
          6.The greyed out icon will indicate the chosen service plan.
          *Contact the market region technical specialist for a confirmation number.
          *Enter the confirmation number.
          *Press Enter.
          *Follow the message set to Exit.
          *Check that the service plan is correct
          You need to contact Xerox Service.
          "Opportunity is missed by most people because it is dressed in overalls and looks like work. "
          • azehnali
            • Nov 2009
            • 679
            The purpose of this post was to avoid calling xerox
            • amadeusmbi
              • 51
              confirmation number is generated in accordance with machine serial number...
              • azehnali
                • Nov 2009
                • 679
                Does that mean I have to call xerox?
                • bojans
                  • 1313
                  Alen did you read PM I've sent to you?
                  • azehnali
                    • Nov 2009
                    • 679
                    I never got the pm
                    can you please resend
                    thanks
                    • bojans
                      • 1313
                      Check PM
