Xerox Phaser 8560DN, Error Code 37,066.48
  • D Colour
    • Oct 2008
    • 213
    [Error Code] Xerox Phaser 8560DN, Error Code 37,066.48
    Hi Guys
    We have a problem with the 8560, giving error code 37,066.48.
    According to the manual 37,066.48: The Wave Amp may be shorted. Check the Wave Amp drive cable (lifted ends of conductors).
    Tried, a new wave amp board and flat cable, power supply and printhead. No luck.
    Code just comes back at start up.
    Any help greatly appreciated.
    James
    Everything that has a beginning, has an end.....
  • landspeeder
    • Feb 2010
    • 355
    Re: Xerox Phaser 8560DN, Error Code 37,066.48
    just wondering if you found what the cause was
    thanks
    David
    You never realize how cheap a professional is until after you let an amateur do it.... and
    if this was an easy thing to do then everybody would be doing it! But it isn't and they are not!!
    • D Colour
      • Oct 2008
      • 213
      Hi Landspeeder. I hear you are the man to get these sorted!
      No, we still have this problem! Any ideas?
      Any help much appreciated!
      James
      • landspeeder
        • Feb 2010
        • 355
        well wave amps are a weak point and changing it is good but I have seen quite a few defective new amps...if the ele mod is alright and the printhead as well then you likely have a bad wave amp again..do you have the service c/d? I will think on it while I'm working on my old dodge neon and get back to you if I think of any other possibilities
        • landspeeder
          • Feb 2010
          • 355
          recheck connections and its gota be the amp are the green leds where you plug in on ...you have to look thru the little holes in the metal case of the ele mod
