X560C Scan Reports
  • Ianizer
    • Jul 2011
    • 380
    X560C Scan Reports
    Hi all,
    X560C-Integrated Fiery, using network scanning. Prints an error report when a scan fails. Sounds reasonable...
    Scan fail is not the problem... That it prints a report with a preview pane is. Security issue for the customer.
    Ideally, we'd like to print a report on failure, but without a preview pane. Haven't found the Preview toggle, so we'll settle for Off.
    In Admin Mode (Tools > Common Svc Setting > Reports), I have a choice of On/Off/Print When Delivery Fails for the Scan File Transfer Report option.
    Interestingly, Scan File Transfer Report is turned off and a report is still generated on scan fail (simulating network connect fail by unplugging ethernet).
    Either there is a SW glitch, or I have the wrong setting entirely.
    Thanks in advance for the feedback. I really appreciate it.
    -I
    My name Peggy.
    You got problem?
  • Ianizer
    • Jul 2011
    • 380
    Re: X560C Scan Reports
    Nobody's got anything?
    -I
    My name Peggy.
    You got problem?
    • seansbar
      • Dec 2010
      • 198
      Not sure in XC560, but other Xerox model have that setting your looking for in the template setup.
      • Ianizer
        • Jul 2011
        • 380
        Thanks seansbar, I think I found it.
        Scan template setup in the web IU on the print engine side.
        -I
        My name Peggy.
        You got problem?
