xerox Pro 412 scanner problem Help!
+ More Options
Posts
  • century
    • 95
    Hello everyone,
    One of my client has a problem with scanner on Xerox Pro 412. After I download driver for Printer and Scanner and installed. The Printer is working fine. But, I can't make the scanner work?
    when I open Scan to PC and hit scan, I can see the paper is scanning but not thing show up?
    One thing I noted is his OS is XP and the driver only has 2000 & NT. But, the printer work fine? and that is only driver I found on Xerox website.
    What am I missing......Please help. Thanks
  • Mr Spock
    Vulcan Inventor of Death
    • Aug 2006
    • 2064
    WorkCentre Pro 412 Drivers and Downloads
    This link shows a XP and a Vista driver and other downloads including the twain driver used for scanning. I believe that is a samsung machine.
    • century
      • 95
      Yes, this is the driver I download. It's say XP but it doesn't has XP in there. (if you download the driver and unzip, then you will see) However, I use 2000 driver for the printer and it's come out ok. But the scanner driver is not work for XP. Do you have any Idea?
      • century
        • 95
        I think I know the the problem. My Twain Driver is not work with XP. But this is only driver that Xerox given.
        It's there any way around that I can make scanner working. Any information would be help. Thanks
        • slaterboy
          I am having the same problem with my WorkeCnetreM20i.
          May your answer can also solve mt problem.
          Thanks,
          Slater
