Document sorting on xerox DocCentre III C2200
+ More Options
Posts
  • hknwbec
    • 214
    Hi, Could you tell me how to use document sorting function on Xeorx DocuCentre III C2200.
    As we don't have finisher on this machine. we want to use build-in sorting function. Is it workable and how to operate it, because there has no such key for sortiing on the display. I know it has no cross sort but it can be moved up & down.up and down. how to ceate a key by using customer button. Thanks & Best Regards
  • TechMate
    • Mar 2008
    • 285
    Re: Document sorting on xerox DocCentre III C2200
    I believe you are referring to the COLLATE function and STORED PROGRAMMING. Both of which are found in the user's manual.
    • hknwbec
      • 214
      Hi TechMate, thanks for your reply, yes I need collate function but I found no hard disk inside the machine, only has a hard disk mount and without ide interface cable. I want to order the related ide interface cable. could you help me.
      • TechMate
        • Mar 2008
        • 285
        Google search or you can find a copy of the user's manual on the xerox website. The IDE interface cable is available from xerox or an authorised dealer as this is not a normal IDE cable. As for the special features of the machine (ie. stored programming, scanning, etc.) you might need a SOFTWARE KEY to activate the function.
        • hknwbec
          • 214
          I have this hard disk power cable, could I only install the SATA hard disk can activate the collate function if we don't need store and scan document function.Do I need to format the hard disk by using the machine service code.
          • copytech200X
            • 264
            you need software key that is unique for this model .
