Transfer Belt Cleaner - Xerox WC 7132
  • wmassmann
  • JustManuals
    • Jan 2006
    • 9838
    Re: Transfer Belt Cleaner - Xerox WC 7132
    This Parts & Service manual can be purchased for $12.77 and downloaded immediately after payment from
    Paul@justmanuals.com
    • amadeusmbi
      • 51
      Originally posted by wmassmann
      Is this the same as a “2nd Btr Transfer Roller”?
      No. Read specification (Laser Toner Cartridges and Supplies for WorkCentre 7132 Multifunction)
      001R00588 IBT Belt Cleaner (Transfer Belt Cleaner)
      008R13021 Waste Toner Container
      008R13023 Fuser Cartridge 220v
      008R13026 2nd BTR Unit (2nd Btr Transfer Roller)
      You can reset (from User Interface - UI):
      IBT Belt Cleaner (Transfer Belt Cleaner) - clean it before reset (3-7 times);Carefully clean the module without deleting the white dust on the blade. Watch the toner strengthened the blade.
      Waste Toner Container - empty container (I recommend you to have one for backup);
      Fuser Cartridge 220v - 1-2 times (until begin to make the duplex jam in the fuser area, without a visible mechanical cause)
      2nd BTR Unit (2nd Btr Transfer Roller) - 2-4 times (until the roll begins to crack)
      "Opportunity is missed by most people because it is dressed in overalls and looks like work. "
      • wmassmann
        Thank you for clearing things up. Your response was most helpful.
