WC 7132 machine noisy
  • copytech200X
    • 264
    hi ,
    my wc7132 machine noisy when machine initialize and i had changed 2nd btr retract clutch ,main drive assy ,drum drive assy but problem still persists...no fault codes appears but first copy only print blur and rest copy print fine.
  • bojans
    • 1313
    Re: WC 7132 machine noisy
    Can you determine from where that noise is coming?
    • JustManuals
      • Jan 2006
      • 9838
      This Parts & Service manual can be purchased for $12.77 and downloaded immediately after payment from
      Paul@justmanuals.com
      • copytech200X
        • 264
        the noise comes when main drive energize 2nd btr ..thanks
        • tech9
          • 216
          Seems like you got a nasty one here, I know you have changed the retract clutch normal cause, have you inspected the dev motor drive gear ? Drums are very noisy but i expect you have changed this.
          Just a thought as you have gone through the main mechanics.
          Very intrested on what the cause is ? please keep me posted.
          • copytech200X
            • 264
            u know the problem from drum assy at auger ..manually drive by hand it's stuck .i had monitor this prob as my tech told me their just change drum assy last 2 months and meter usage only 5000 print..update all of u if prob rise again ..
