WC M24 Touch Screen
  • jcontractor
    • Aug 2010
    • 247
    WC M24 Touch Screen
    Hi,I have a WORKCENTRE M24 with problems in the touchsceen display. It beeps like it is receiving the command but it doesn't perform the disidered changes. Basically it detect only the fingers vertical but not horizontally. In consecuense only very few commands are performed. I can't navigate truth display horizontal tabs. I can view only few horizontal function buttons in the first tab of the display.Any ideas or any experience with similar display failures.Thanks in advance.As far with this failure I can't access service mode and I don't have PWS.
  • adriansto
    • 2387
    Re: WC M24 Touch Screen
    As I said in your previous topic you need pws and diagnostic software.
    In that way you can make the machine to work at least at a printer, scanner and copier with basic functions. This is the cheaper solution.
    The display is very expensive until you dont find it at second hand.
    If you agree this cheaper solutions then send me a mail at stoadis@gmail.com
