Xerox DC440st card scan
  • Enzo
    • Jul 2009
    • 407
    [Misc] Xerox DC440st card scan
    Hi friends. I have 5 dc440st Xerox and all network connected. But none of them do network scanning. My question is: we need a network card or you have to do some work in the machine? My Xerox technician told me that there is only need the floppy with data to enable scanning steep. is that correct? friends help me because I need the network scanning. Thanks
  • adriansto
    • 2384
    Re: Xerox DC440st card scan
    Yes you need only diskette to activate scan to net and scan to mail also lanfax.
    Why your tech dont activate it ?.
    • Enzo
      • Jul 2009
      • 407
      My friend, I do not know why my technician did not activate this setting! You can send data to the floppy? can you tell me how to activate it? very nice man!
      • Mr Spock
        Vulcan Inventor of Death
        • Aug 2006
        • 2064
        These were not standard issue they were options. They are expensive options and you need to buy the floppy for each option and for each machine. Once installed the floppy can not be used on another machine. At least not easily........
        The floppy is a proprietary format and can not be duplicated.
        • azehnali
          • Nov 2009
          • 679
          you need the scan board first of all
          then the floppy to activate it
          the floppy is serialized to the copier but you can change the copiers serial # to the one you use the floppy on and it will work
          • adriansto
            • 2384
            Is a DC440 machine and it have the scan interface on it if he can print with copier.
            In Hodaka machine you need a small coupling interface.
            SOme photos of the board on the back of the machine are useful.
            • Enzo
              • Jul 2009
              • 407
              my technician told me that the machine is predisposed for the scan, but I only need the floppy virgin. I am able to change the serial number of the machine, so I just need the data on the floppy. Can anyone help me?
              • ingmaster
                • Mar 2011
                • 39
                I have diskette image with activation manual. Write to PM.
                • Enzo
                  • Jul 2009
                  • 407
                  Hello friend. A friend gave me the disk with data to enable the scan! New features have appeared on the machine (scan and email) but the machine does not work anymore! it turns on and when the network controller is 70%, the machine restarts but the screen remains for hours "please wait ... Warming up."
                  What happened? now the machine is down and I would fix it. Thanks friend.
                  • Enzo
                    • Jul 2009
                    • 407
                    need or no need for the card? I have not yet understood. I enabled the options using the floppy disk but the machine reboots without being able to use!
                    • adriansto
                      • 2384
                      Some pictures of the board on the back of the machine are useful.
                      • Enzo
                        • Jul 2009
                        • 407
                        <script src='http://img80.imageshack.us/shareable/?i=immag0313.jpg&p=tl' type='text/javascript'></script><noscript></noscript>
                        This is my back to dc440st.
                        • xcopytech
                          • Aug 2006
                          • 1792
                          put pictures with all cables connected to ESS
                          • adriansto
                            • 2384
                            I ask you some photos of the board and you post the connectors for ESS picture. So that is !
                            Look at the last picture ( FIG 6 ). If you dont have all cables like in picture you dont be abble to scan.
                            For scan options you need scsi cable on right hand connector and hdif board like in FIG1.
                            If your xerox tech told you need only diskette for scan without have scsi cable then I think he is not a xerox tech. May be he is a painter !
                            • Enzo
                              • Jul 2009
                              • 407
                              [ATTACH=CONFIG]11799[/ATTACH]
                              my technician was convinced that my machine was already set to scan, but he has never seen! Tomorrow will post a full picture of all the cables. You can post better pictures? The resolution is very low and I can not see well.
