Anybody know how to do it?
5225 conversion from metered to sold
CHIEFCOOKBOTTLEWASHER
Re: 5225 conversion from metered to sold
Just ran into this issue with one of my 5225 machines. I thought I could easily change the NVM from Metered to Sold but I cannot access the NVM to change it. And I am a little baffled cause the toner I am having issues with has the exact same part number chip in it.
Did you have any success converting from metered to sold? If so would you kindly share a little advice to a guy pulling his hair out at the moment.Comment
As a Xerox service tech, the only way I know of doing this is through the Xerox Tech Support helpdesk. The NVM setting for this is read only. It requires a file to be uploaded to the machine provided by Xerox. There may be unscrupulous ways of doing it that I am not aware of. I know the file sent by Xerox is based on a number of machine specific data including the current meter reading. If more than a few 100 copies are made after this file is created, it is no longer usable and will not work anymore.Comment
Toner Guy
from the Xerox website and our own experience, moving a xerox machine from metered to sold simply requries a sold version cartridge to be installed. The machine now requries a sold cartridge and will not accept a metered version. To change back would require the OEM's help.
have you experienced something different?Comment
