DocuColor 12 error after installing new parts
  • industrifox
    • Sep 2011
    • 20
    Greetings, Copytechnet community.
    Hopefully I can give helpful hands as well, but I am new to this industry. I work preflight and I have a DocuColor 12 sitting in my office I am supposed to maintain.
    After some problems, and trouble shooting I needed to put in new parts. an IBT Belt, a new Copy/Print drum, and a 2nd BTR Roller.
    After I installed those prints came out better but seemed to be off, but I was at the end of my shift so I left.
    This morning all it does now is feed me this error.
    Quote-
    System Fault.
    1. Turn power off. The switch is on the right side of Copier/Printer.
    2.Pause, turn power back on.
    9-342
    -End quote.
    I'm trying to find this in my documentation I have provided here.. but I don't know much bout this machine. Is anyone willing to help, please? I can try to provide further information if needed.
    Thanks in advance.
  • industrifox
    • Sep 2011
    • 20
    Re: DocuColor 12 error after installing new parts
    9-342.... I did just install a 2nd BTR roller... no grinding though.... maybe a squeak sound would be the same?
    • industrifox
      • Sep 2011
      • 20
      That wheel on the roller with that yellow mark... should that yellow be shown through the hole on the front of the tray? (tray - where the handle is to pull the guts out)
      • maich4s
        • Mar 2009
        • 86
        The Control Logic has detected that the 2nd BTR failed to contact the IBT.
        that isnt abig problem,kindly remove and takeback the 2nd ibt assembly.also make sure that its rotating freely and that the 2nd btr sensor is well seated
        • industrifox
          • Sep 2011
          • 20
          I'll try this and report back, I'll make sure everything in the assembly is functional as well again, thanks for that.
          • bojans
            • 1313
            Like maich4s suggested first check sensor if it poped up, you could also clean it.
            Also check Main Motor (dC330 - 004-007) is it working normal.
            In couple cases with intermittent 9-342 and 9-343 it was defective Front Door Interlock
            • JustManuals
              • Jan 2006
              • 9838
              Paul@justmanuals.com
              • industrifox
                • Sep 2011
                • 20
                The front door does close tricky..... its something to do with the casing.. could that b it and finally years later give this code?
                • industrifox
                  • Sep 2011
                  • 20
                  Just finished this, still experiencing the same.
                  However in searching for it I did find this which is nice and handy for the future
                  TOTO 4D merupakan situs toto 4d resmi dan terpercaya yang hadir di Indonesia. Sebagai platform permainan togel 4d online yang memiliki lisensi resmi jelas akan menyediakan berbagai pasaran togel terlengkap dengan minimal bet 100 rupiah saja kalian sudah bisa mendapatkan hadiah jacpot terbesar 10 juta. Memiliki sistem keamanan yang tinggi dan bisa dipercaya setiap membernya. Sehingga TOTO 4D sangat diakui sebagai situs toto 4d terpercaya dengan memberikan pengalaman bermain togel yang menyenangkan dan menguntungkan. Situs Toto 4D ini akan memberikan peluang kemenangan yang besar dengan berbagai bonus promo menarik yang bisa kalian dapatkan jika bergabung Bersama situs TOTO 4D. Terdapat fitur layanan pelanggan yang siap dalam 24 jam penuh untuk membantu setiap kebutuhan anda. Daftar sekarang juga di situs toto 4d dan dapatkan hadiah jackpot terbesarnya.
                  I'm going to try to just see now if its the oor like mentioned in the latter.
                  • xcopytech
                    • Aug 2006
                    • 1794
                    Cheat front door interlock and check does your 2nd btr roll go up and down when power on machine.
                    If roll go up and down then your problem is sensor.
                    Remove 2nd btr assembly and check sensor and clean it.
                    If cleaning does not resolve your problem then you can remove paper feed assembly (any) and remove one sensor from it and replace 2nd btr sensor with it.
                    • industrifox
                      • Sep 2011
                      • 20
                      I reassembled the BTR assembly and it started working fine. Other than now that toner leak issue I posted/registration..
                      This thing is definitely giving me a work out.
