WC 5225 - No duplex option on display
  • cozzy15
    • Sep 2011
    • 7
    [Misc] WC 5225 - No duplex option on display
    Hi all,
    I have a Workcentre 5225 which doesn't show the duplex option on screen. I have been told this option is plug & play. I have swapped duplex unit onto another machine & it shows straight away so the fault is definately on the machine. When I open the duplex door it says "close duplex door" and the rollers in the duplex turn when door is closed, so power is at duplex. Can't see a setting to disable/enable the option.
    Thanks in advance.
    Paul
    Nottingham UK
  • johnner66
    • Mar 2009
    • 265
    Re: WC 5225 - No duplex option on display
    first is your copier come with harddisk and how many ram your copier have good luck
    • adriansto
      • 2384
      Hdd even ram is no problem for you have duplex mode.
      Check all the wires and connectors from exit assy. Check the link between exit assy and others machine components.Exit_Assy.jpg
      • cozzy15
        • Sep 2011
        • 7
        thanks it was a loose connection on exit assembly
