BRT retract fail.
+ More Options
Posts
  • olaolaking
    • Sep 2011
    • 14
    BRT retract fail.
    I just run into another error now. The error code is 009-358. When I
    check, It was 2nd BRT retract fail.
  • bojans
    • 1313
    Re: BRT retract fail.
    Are you talking about Xerox DC 12?
    • olaolaking
      • Sep 2011
      • 14
      Xerox dc 2060
      • bojans
        • 1313
        So did you find solution to your problem?
        • olaolaking
          • Sep 2011
          • 14
          I am still searching for solution
          • bojans
            • 1313
            Did you check wires?
            • olaolaking
              • Sep 2011
              • 14
              I just bought the machine 3 weeks ago. I am new completely to the machine. I do not know what to do as at now. Can you help me? I am just a complete newbie
              • bojans
                • 1313
                If you never worked on this one before, better call a tech to do a service and diagnose whatever problem exist. In the same time you can watch and learn basics operations performed by tech, and in future you'll be able to solve incoming problems.
                Cheers
                • olaolaking
                  • Sep 2011
                  • 14
                  The tech are making things so difficult. For more than 2 weeks now I have been calling them but they never pick the call
                  • bojans
                    • 1313
                    Just got a call from customer with the same code. I'll check out tomorrow, and keep you posted.
                    • olaolaking
                      • Sep 2011
                      • 14
                      Ok
                      I will appreciate it if you can helpme out
                      • kalindd
                        • Jun 2008
                        • 192
                        It can be caused from BGM drawer problem, not latching properly check here download both pdf files http://www.copytechnet.com/forums/xe...arming-up.html
                        Or by this connector (red circle) replace ALL the wires that goes to 2ndBTR
                        Good luck.
                        • GusG
                          • Jul 2008
                          • 198
                          Some time ago I had a 2nd BTR retract fail issue on my 2060, I discovered that when I closed the drawer and after turning the handle to lock the drawer and folding the handle up and could turn it a further little bit ccw so that the handle stayed up, this last little turn caused the failure and when I didn't do the last bit I didn't have the issue.
                          • bojans
                            • 1313
                            Been on the site today, and found that one wire on P705 was broken. It's a plug with three wires. Check pictures.
                            • olaolaking
                              • Sep 2011
                              • 14
                              Thank you friends for your support so far. I am highly impressed by your response so far.When I followed your comments I discovered that the -[handle shaft gear (P/N 7E55160)] is broken. And fromevery indication It wil have tobe replaced. Please where can I get one to buy?
