Xerox Workcenter Pro 40C fault codes!
  • Kevin57
    • 18
    Okay, put on your thinking caps! Here's one that's got me going in circles. The above named color copier/printer has fault codes(3.316.00, as an example) which will not clear. I have tried asking Xerox related companies on the web but this model seems to be elusive when it comes to a service manual or information whatsoever. The only information available is through Xerox which is a bit expensive and they won't sell just to anyone. Anyway, I don't normally work on the newer Xerox copiers just for this reason, but it is a major account and the machine has been down for 2 weeks. Hence, I have turned to all the smart techs who might know something about this machine. I would really appreciate any information on this model explaining the error/fault codes. At least I'd be heading in the right direction with this machine. I'd be more than willing to pay for a copy of the service manual if anyone knows where I might obtain one. Thanks as always for the help in the past and I hope I can do the same for someone in return!
    Kevin57
  • xcopytech
    • Aug 2006
    • 1792
    xerox wcp40c
    03.316, 03-516 CCM IOT Communication Fault
    CCM can not communicate with the IOT.
    The scanner and copier are disabled but printing is operational.
    Procedure
    NOTE:
    An IOT +3.3 VDC failure will cause this fault.
    Check for +3.3 VDC between the gray and violet wires at P510 on the IOT +3.3 VDC LVPS (
    PL
    9.1
    ). +3.3 VDC is measured.
    Y N
    Go to the
    OF 1-1 IOT +3.3 VDC RAP.
    Reset the Main Controller or Switch the power off then on. If the problem continues, perform
    dC402
    SW Verify.
    best regards
