Xerox dc 250 Image issues
  • vibin
    • Sep 2011
    • 38
    Hi all,
    I have a Dc 250 with cx 250 creo. Please see the problem below and advice. its on all colors, we had the Ros cleaned, IBT changed and tried switching drums but still have the same problem. Please advice
  • azehnali
    • Nov 2009
    • 679
    Re: Xerox dc 250 Image issues
    what if you use the glass and make a copy?
    • vibin
      • Sep 2011
      • 38
      No change at all even when you make a copy from the glass.
      • azehnali
        • Nov 2009
        • 679
        then the problem is the machine and not the rip
        isolate the problem
        is it all the colors?
        • vibin
          • Sep 2011
          • 38
          all colors except black
          • azehnali
            • Nov 2009
            • 679
            Run 100% cmy individually and post pictures
            • vibin
              • Sep 2011
              • 38
              Thanks for this.
              These are in 20 %
              SpireColor200_1S168.pdf
              These are in 100%
              SpireColor200_1S173.pdf
              Vibin
              • GusG
                • Jul 2008
                • 198
                Did you try to change the developer material?
                • azehnali
                  • Nov 2009
                  • 679
                  Looks like drum and developer issues
                  Have you replaced drums ?
                  • vibin
                    • Sep 2011
                    • 38
                    Drums have been replaced.
                    Cud it be the housing or just developer material itself?
                    Regards
                    Vibin
                    • azehnali
                      • Nov 2009
                      • 679
                      Out of the cmyk prints which ones look bad
                      • vibin
                        • Sep 2011
                        • 38
                        Yellow, followed by magenta then Cyan
                        • azehnali
                          • Nov 2009
                          • 679
                          where are you located
                          are you a tech or an end user?
                          • adriansto
                            • 2387
                            Do a print from this document and then post here page 3,4,5,6.
                            Also make a copy of printed page 3 from platen glass and post it.
                            Your ibt belt cleaner is not in good condition. For moment your drums and developers are ok
                            toner_test_targets_600dpi.pdf
                            • fix the copier
                              I was reading this because i am having the same problem. This copier is making the same image but is not on black only color. just about to repace ibt belt .One thing i heard thru the grapevine is this copier has 2 laser units?
