workcentre c2424
+ More Options
Posts
  • Luther
    • May 2006
    • 682
    workcentre c2424
    I was asked by a customer to take a look at this machine while i was there servicing a canon, as soon as you turn it on it goes to a code:37.004.40, any help in way would be appreciated...thanks in advance
  • bojans
    • 1313
    Re: workcentre c2424
    Found this in Eureka
    PROBLEM:
    Insufficient AC Power Can Cause 37,002 thru 3737,002.47 or 37 Reservoir heater, 37,004.40 or 37,005.413737,008.44
    Ink melters errors 37,009.45 thru 37,013.40
    CAUSE:
    The printer features several heaters controlled by printer electronics and powered by AC electricity. The printer itself can power up despite insufficient or irregular AC voltage but it may fail its AC heater tests. This is due the test not measuring sufficient current flowing through the heater at the moment the test runs.
    Devices sharing the AC circuit shared with the printer, such as a laser printer pulse-heating its fuser, a coffee maker heating its warming plate via a thermo-breaker, or a space heater turning on, may be placing heavy intermittent demand on the AC circuit. This sudden inductive demand creates momentary AC voltage sag that causes the PEST test to fail.
    SOLUTION:
    Verify the AC power source when you troubleshoot a printer exhibiting any of these errors. Try powering up the printer on a different AC circuit on a different breaker. Turn off other devices, such as laser printers and coffee makers on the same circuit.
    • Luther
      • May 2006
      • 682
      Thank you bojans...thats a huge help!!
