042-326 Error Code on Docucolor 240
  • azprint
    • Aug 2025
    [Error Code] 042-326 Error Code on Docucolor 240
    How do I fix an error code 042-326 on my Xerox Docucolor 240? I've read that I should clean the transfer belt but have no idea how to get to it. Thank you for your help.
  • azehnali
    • Nov 2009
    • 679
    Re: 042-326 Error Code on Docucolor 240
    you should buy a manual
    its only like $10
    • azprint
      its only like $10
      Where can I buy a manual for $10?
      • azehnali
        • Nov 2009
        • 679
        look on ebay
        • azprint
          look on ebay
          There aren't ANY listings on eBay for a Xerox Docucolor 240 Manual.
          • azehnali
            • Nov 2009
            • 679
            look up another model
            that guy sells all the models
            • adriansto
              • 2392
              42-326 may have multiple cause. Where are you from ?
              • johnner66
                • Mar 2009
                • 265
                try reset the nwm 741-105 and 741 -106 to 0 and make sure the ibt small reflector is there good luck
                • azprint
                  Don't see the IBT reflector. Do you know where to get a replacement patch?
