Workcentre 7665 Error code 03.347.00
  • hobey
    • Aug 2025
    [Error Code] Workcentre 7665 Error code 03.347.00
  • adriansto
    • 2388
    Re: Workcentre 7665 Error code 03.347.00
    Error mean the UI can't comunicate with Copier Control Module but also there are another error codes not displayed. You can see all error code with PWS. Because the scanning function dont work I think is a problem of comunication between net controller and UI but this depends by firmware version the machine have. May be a net controller software corruption.
    Post here an report configuration from machine.
    Will be great if you have an old configuration report before the machine came in error.
    • maich4s
      • Mar 2009
      • 86
      the way forwad is to get a service engineer with a pws and network controller software so that he can do software installation.
      • hobey
        Thank you both. The users didn't want to wait for operations to figure it out so they called in a tech. I do not know what he did, but he fixed it and it is working now. Thank you for your responses. I appreciate it.
        ~Hobey
