Error when run "wcps diagnostic navigator" in workcentre pro c3545
  • yourri
    • Jul 2025
    [Error Code] Error when run "wcps diagnostic navigator" in workcentre pro c3545
    hello everyone! sorry about my bad english
    when run "wcps diag", following the message "communication problem encontred ..." a get this screen :
    so, please help me!! where is the problem ? what can I do to run it correctly ?
    os: win xp sp3
  • yourri
    Re: Error when run "wcps diagnostic navigator" in workcentre pro c3545
    No one did encounter this problem !!!
    appears at the beginning this window :
    after :
    • yourri
      hi
      the problem was in the USB drivers (we must have : SIPUSBDR.INF and SIPUSBDr.sys). finally I get a wcps executed. and a get this screen :
      i check battery on CCM PWB, the voltage is 1.24 V.
      is that I can start the machine keeping this battry (disappearance message : communication probleme encountred reset system by turning power off...)
      by using dc105 and dc133 ?
      Can someone explain this method in detail ?
      thanks.
      sorry for my bad english
      • bojans
        • 1313
        Get a new battery. It must be at 2.8 V
        • yourri
          hi thanks bojans
          yes i now we mast change the battery. bat my question is possible to start the machine "without message error" using wcps diag DC105 and dc133 as in this article:
          I have a 03-338 fault code on Xerox 2636. I was - FixYa
          I seek the mehode
          • ravilanb
            • May 2011
            • 24
            yes machine will work till the time you dont switch off the m/c
            • yourri
              hi
              yes, but how I can operate the machin to print. ?
              you know how?
              plz help
              • ravilanb
                • May 2011
                • 24
                Originally posted by yourri
                hi
                you know how?
                plz help
                once the display comes on,display show m/c in diagnostic mode.you exit the service mode.then you can take prints on it.
                • yourri
                  thanks raviland for your answer.
                  I tried to follow your method. can you explain more. the problem la machine still displays the message "communication probleme encountred...
                  please more help. I need to run the machine
