Docucolor 260 Touch Screen
  • tpd
    • Nov 2024
    [Misc] Docucolor 260 Touch Screen
    Have just started up machine to find that the touchscreen does not respond. It turns on and loads to main menu but will not respond to touch. Any ideas out there??
  • azehnali
    • Nov 2009
    • 679
    Re: Docucolor 260 Touch Screen
    looks like you need a new screen or repair
    • bojans
      • 1311
      Hi Alen,
      how do you repair these?
      • adriansto
        • 2309
        First try to disconnect then connect the cable from UI to CCM.
        If this dont work see in service mode if there is any error code.
        For your UI monitor has wo components:
        Panel and touch panel. You need only touch panel if it is faulty.
        • adriansto
          • 2309
          Originally posted by bojans
          Hi Alen,
          If you are lucky enough after disassembly and reassembly of UI assy it's works.
          • bojans
            • 1311
            Tnx Adi,
            Yes I know all this. But disconnecting and disassembling helped only once, and only for couple days.
            Reading this post thought that there were a way of fixing touch panel .
            Cheers
            • azehnali
              • Nov 2009
              • 679
              you can disconnect and reconnect for 100 million years and it will never work
              you need to reheat the screen contacts and apply pressure so the glue reglues the reassemble
              • bojans
                • 1311
                Thanks for the tip
                • bojans
                  • 1311
                  Can I do it with hot air?
                  • azehnali
                    • Nov 2009
                    • 679
                    use a heat gun
                    dont get too close to the screen
                    do it on the back side only
