7345 jams stuck due to static on IBT 008-164
  • tech9
    • 216
    Hi fellow techs
    i have a 7345 where due excess static on the IBT the paper sticks with a fault code 008-164.
    i have tried a new 2nd BTR and clean around that area.
    Any ideas ?
  • johnner66
    • Mar 2009
    • 265
    Re: 7345 jams stuck due to static on IBT 008-164
    is deu to the pob sensor fault replace the sensor beside the regi.. sensor good luck
    • simple mind
      • Aug 2009
      • 39
      Originally posted by tech9
      Hi fellow techs
      Any ideas ?
      If the paper is folded next to the registration rolls with jams and 008/164,and no success with POB sensor ,you should change the registration clutch P/N: 121K22220.
      • tech9
        • 216
        Turns out that it is the paper causing the problem.Tried headed thicker paper what was available works fine.
        Thin no branded paper just sticks to IBT.
        For your help
        • xeroxsharp
          • Nov 2008
          • 270
          Hi fellow techs
          Any ideas ?
          Only guess.
          Maby you need to inspect duplex unit,if the problem is produced in two-sided printing.
