xerox 5018 power supply
  • gerry m
    I suspect my problem to be within the power supply. I have removed the fuser assembly and can see the power supply below with at least 1 electrolytic
    capacitor defective. My question is how to remove the 5018 power supply board for repair? Thanks
  • Mr Spock
    Vulcan Inventor of Death
    • Aug 2006
    • 2059
    Easiest way is to replace the machine.
    Other than that:
    low voltage power supply
    remove the fuser
    remover the tray one feed unit.
    unplug the connectors
    remove one or 2 screws and lift it up and out.
    high voltage
    remove the low voltage power supply (see above)
    remove one screw
    remove the connectors
    stand on head while wiggling the power supply out of machine.
    Watch the last connector while removing power supply.
