Programmer
  • bojans
    • 1313
    Programmer
    Hi all,
    I got programmer AllPic and can read and write data on 24Cxx chips.
    Does anybody know how to connect wires on Xerox01/90 chip, or have software for this operation.
  • adriansto
    • 2375
    Re: Programmer
    You cant read or write all memory area with this programmer. The connexions is same like 24xx
    • bojans
      • 1313
      Re: Programmer
      So the structure is the same as 24Cxx chip.
      Do you know which programmer I need?
      Thank you
      • adriansto
        • 2375
        Re: Programmer
        Thank you
        What you want to do ?
        • bojans
          • 1313
          Re: Programmer
          I want to reprogram chips for xerox 2240 and 2128. I have this machine in my office and use it for printing bills. Also have friend with programmer for all kind of chips, but when i got this programmer wanted to do it by myself. I'm just curious how does it work.
          • adriansto
            • 2375
            Re: Programmer
            xerox90.pdf
            In blue area you can write 1 to 0. Can't revert back to 1 from 0
            • bojans
              • 1313
              Re: Programmer
              Thanks mate for your interest.
              At least I can boost your rep.
              Cheers
              • adriansto
                • 2375
                Re: Programmer
                Thanks !
                • bojans
                  • 1313
                  Re: Programmer
                  Hi adriansto,
                  Can I use SEEPROG for writing xerox 01?
                  • adriansto
                    • 2375
                    Re: Programmer
                    Hi adriansto,
                    No.
                    You can use an older programm to write first half of Xerox01 like 24c01 but I dont know if that help you.
                    • bojans
                      • 1313
                      Re: Programmer
                      Ok, thanks mate
                      Do you know which programmer can do that?
                      • adriansto
                        • 2375
                        Re: Programmer
                        Ok, thanks mate
                        Pony Prog can do but an older version who know to programm only 1Kb eeprom 24c01.
                        Programmer is only an interface. The software must do all job.
