Need help resetting NVM on Xerox 7655.
  • jryan15
    [Error Code] Need help resetting NVM on Xerox 7655.
    Hello all! Recently out Xerox 7655 went down reporting a 42-326 error. I was able to pull the IBT belt and clean the silver patch and the sensor (as well as I could), but the fault persists. I read that I need to access the maintenance menu and reset NVM 741-105 (as well as possibly complete a belt edge learn cycle).
    I've tried several different ways of holding "0" for 5 seconds and pressing the start button, but I can't seem to access the maintenance menu. I can log into the admin side using the default password, but I can not find the NVM to reset it to "0".
    Any help would be greatly appreciated. Thanks!
  • JustManuals
    • Jan 2006
    • 9838
    Re: Need help resetting NVM on Xerox 7655.
    Paul@justmanuals.com
    • fogra27
      • Mar 2011
      • 29
      to enter diagnostic hold # * and Stop, then 6789.....
      • jryan15
        Thank you! Will try this asap!
        • jryan15
          Alright, I was able to access the service menu... Unfortunately I was not able to reset the NVM. I found the "NVM Read/Write" button inside of the "Adjustments" tab. However when I launched the "NVM Read/Write" routine, I did not see a means of accessing a particular NVM. Instead a "Service Name" box opened with several options, Diagnostic Service, Copy Service, Mark Service, etc.
          In looking around I was able to complete a "Belt edge learn" cycle, but the machine still boots up with a system fault. It continues to report an error 42-326. Any help would be great!
          • adriansto
            • 2392
            May be other errors. Follow procedure from service manual for 042-326 error.
            What software version have the machine ?
            • jryan15
              I wish that I had access to a user manual. We are going out of business and mgnt just decided to quit using the copier. I'd still like to continue my quest to fix it though. The IU software version is 040.032.53080.
              • adriansto
                • 2392
                This is a Patriot machine and dont have complete diagnostic only on User Interface.
                You need pws diagnostic tool to have acces at whole diagnostic. And service manual is a must.
                • WIWA
                  • Mar 2009
                  • 97
                  Hello, just in case it happen to me once check the belt orientation may you reinstalled backward and the patch is located at the other end , by the way their is a retrofit to prevent the code.
                  Hope this helps,
                  Wiwa 72
                  Gonzos Build v. 1.0
