xescan for 510dp
  • walidcharifi
    • Feb 2011
    • 379
    xescan for 510dp
    hi
    i find a software XESCAN for scanner wide format
    i have a solution 510dp
    and I can not install the scanner to scan to pc
  • technogeek2009
    • Mar 2011
    • 167
    Re: xescan for 510dp
    The XES Scan software is not used with a standard 510DP system. The XES Scan was a standalone Synergix scanner connected to a PC workstation.
    If you want to print to a 510 DP, you will need to use the print driver available from the Xerox Support & Drivers website. Select the Wide Format Product Family, then the 500 series. Once in the 510 section, go to the drivers and downloads for a 510 DP with YKE Controller. When installing the print driver, the TCP/IP port needs to be4 changed from the default value of 9100 to 2000.
    • walidcharifi
      • Feb 2011
      • 379
      thinks my freind
      i have a scanner synergix with license color and license copy to net
