Workcentre 7232 Error Code 089 - 311
  • leoace
    • Jan 2012
    • 12
    [Error Code] Workcentre 7232 Error Code 089 - 311
  • xerotec
    • Oct 2009
    • 45
    Re: Workcentre 7232 Error Code 089 - 311
    Look IBT cleaning blade assy for waste toner if is full clean and clean way to waste toner container.
    Chek 2BTR.
    • leoace
      • Jan 2012
      • 12
      **EDIT
      Found the eureka Tec Tip about the IBT Belt drive roll bearing wich is kept in place by a simple rather thin metal plate wich can be deformed sometimes. This causes squeeky noise and can cause a bad /loose contact between drive roll and drive dock at the backside in the machine. We carefully pulled the metal back to its position to reduce / remove the free space. We also decided to replace the 2nd BTR Roller since its far from beeing good and may cause problems with the new IBT Belt unit.
      At the moment, machine is working.
      • Original1
        Originally posted by leoace
        **EDIT
        Where is this plate / bearing located got one doing the same thing
        • adriansto
          • 2369
          PL 6.2 item 8,9 & 10. Check also rear contact arm and if the drum cartridge release lever- PL 6.1 item 8- is into corect position. If everything ok then you must check the home belt sensor if is good.
          • leeschlender
            I cannot find the eureka docs for the belt assembly. Can anyone tell me how to take out the lbt belt and clean the patches ? I do not know
            where the belt is located; how to see it, etc.
            Lee
            • adriansto
              • 2369
              If you dont know where the belt is located you need to call a tech. This is the best solution for you.
              • leeschlender
                You are absolutely correct on having someone look at it.
                Problem is ; I am in the middle of the great state of Idaho and there is not a dealer within 50 miles.
                The machine has worked perfectly for many, many years. Only error code I have ever had.
                If I had a manual, I could likely perform the fix. Have to do it all , out here.
                Thanks,
                Lee
                • dorez
                  • Feb 2013
                  • 73
                  Thanks,
                  Lee
                  Check your Private Messages..
                  • leeschlender
                    Thank you for the manual; it is really appreciated !!
                    Lee
                    • nilak
                      • Aug 2010
                      • 72
                      604K45000 or 604K45001 is the kit to repair the IBT patches (2 on the belt). The root cause usually is the cleaning blade seal on the front side. Check Your new Edoc for DC330- 091-005 to run the IBT and inspect the patches (left hand door open and cheated). With some luck and dexterous You can repair it without any disassembly. If the kit is not disponible any polyester self adhesive reflecting foil can make the job (yes You have to cut it to appropriate size). The PVC is too thick, don't use glue - it doesn't pace with stretch cycles. Don't forget to change (repair if You feel capable) the cleaning unit.
                      • drewski
                        Hello everyone-
                        I have a Xerox WorkCentre 7232 that is throwing a 89-311 fault code as well. I know can repair this or diagnose and suggest a new belt/sensor but I can't figure out how to get the transfer belt out. I have about 7 years experience on Konica Minolta products but have never taken apart any other manufacturer machine. Could someone kindly walk me through the itb removal process or possibly share a service manual with me? I have nearly every KM manual under the sun if someone wants to trade. Thanks in advance.
                        • bobbydigital
                          Hello, I'm from Bulgaria. I need manual for replasing IBT belt on Xerox 7232.
                          • andreus
                            Hello, I' m tech, where can I find a service manual of wc 7232 ? help me pleasee
                            • gilbermar
                              • Apr 2020
                              • 6
                              Hola alguien puede ayudarme a encontrar el manual de servicio de xerox workcentre 7242 para asi poder reemplazar la correa ibt o banta de transferecia.
                              saludos cordiales, agradeciendo de antemano.
