Xerox 7665 white thin line across paper
  • Alex5213
    • Dec 2011
    • 26
  • Flash
    • 378
    Re: Xerox 7665 white thin line across paper
    You can try swopping the magenta and cyan drum and check the magenta mag roller and check the print head window.
    • johnner66
      • Mar 2009
      • 265
      this could be the magenta laser unit got dirt inside try the drum first then the laser good luck
