Dc 5000 AP
  • Leonardbez
    • Jul 2025
    Dc 5000 AP
    Hi my Dc5000AP got 1mil on the clock.Got watermarks on 128 coated stock paper.All other stocks are fine.Got a new fuser roll and checked the pressure settings.On single sided print you dont see the watermark so clearly but on auto duplex the watermark is very bad.Played with the fuser temp settings no luck.Fuser oil pumps ok
    Please can someone help !!!
  • davidj7
    • 1107
    Re: Dc 5000 AP
    the problem would be with p/r belt assy . check the blades in the p/r are okay . i normally have to replace the p/r belt assy after 1 mil.
    i need an info from you . how long would it take to print 100 prints of 12.6x192.2 , 220 gsm paper .
    thanks
    a machine is only as good as your tech : source:screwtape ; the scary one
