CC123 add Network Board gives 116-839
  • imagewalker
    • Jun 2010
    • 94
    [Error Code] CC123 add Network Board gives 116-839
    I have a CC123 i purchased a postscript network board with memory on board.
    I keep getting a error code reboot 116-839........ checked the manual but i don't have that
    code in there??? I also checked the user manual. Am i missing the assessors input code???
  • tech9
    • 216
    Re: CC123 add Network Board gives 116-839
    The control logic detected that the required RAM capacity is not installed or available. Procedure
    Remove and reinstall the DDR DIMM
    If the problem persists reload Firmware
    If the problem persists replace the DDR DIMM
    • imagewalker
      • Jun 2010
      • 94
      Thanks ill give that a try.....
