Advice on Xerox Doc Center
  • DClair
    Hi -
    I am looking at either a 255ST or a 265. I need about 50,000 duplexed 11x17 copies per month. Any advice on the better machine would be appreciated.
    Is there any one in New England that does service on these machines - in particular, in Boston?
    Thanks in advance for the help - Dennis
  • xcopytech
    • Aug 2006
    • 1794
    dc 255 - 265 st
    Good machine, but this machine have old controller, so if you gona print some big pdf files it will take you some time for ripping.
    You have to find tech with xerox pws, because only way to enter in diagnostic mode is with laptop connected on machine.
    Fuser module life is over 400.000 copies
    Photoreceptor module about 200.000 copies.
    To have machine in good shape and with good print quality clean donor roll every 100.000 copies.
    • vertavia
      better use apeos port machine
