I don't know the proper way to setup smb file transfer in a workflow template. I guess I need to know how Xerox likes the Destination and Path setup. Systems are running windows 7.
Notatechie - "I am trying, but I don't know how to go into Service Mode. If I just go in and press *then 2, than 8, then * it does not do anything."
SCREWTAPE - "Try harder.."
Gee Adriansto, you have shown me a better way! All these years I've been guessing and faking my way through life, but you sir have now put me on the right path!!! thank you sir I am eternally gratefull...
And now back to reality,
I setup a WC 7120 this morning, and putting the pc name as the Destination and the shared location in Path and it worked fine, but not on the WC 7535 it still doesn't work, is there a specific syntax that is needed for the 7535?
No, there is the same procedure for both machine. Generally speaking the copiers must have same activated network services so take a look at the configuration report from 7120 and compare with config report from 75xx machine.
And remove Windows Live from your PC station.
The firmware of 75xx machine is ..... ?
