Xerox 7530 ID CARD COPY function
+ More Options
Posts
  • lelix2603
    • Aug 2025
    Hi
    In the Xerox 7120 there's function "ID Card Copy", in 7530 this feature is not present ...
    how can I do this kind of copy?
    I activated the two-sided copy and two image in one copy, but the two image is enlarged and adapted to the page
    it is possible that the image is not enlarged?
    thanks in advance
    Annulla modifiche
  • Flash
    • 378
    Re: Xerox 7530 ID CARD COPY function
    Return to Search Results
    User Level General User
    Minutes
    Solutions for : How To Make a Copy of an ID Card Using One-Button Access
    Solution : Create the ID Card Copy Function and Save the Settings for Future One-button Access
    The following procedure is used to create a one-button function to copy both sides of an ID Card or similar two-sided document onto one side of a sheet of paper.
    1. Press the [Services Home] button on the Control Panel, and then select the [Copy] button on the Touch Screen.
    2. If necessary, select the [Copy] tab on the Touch Screen.
    3. Select a paper tray containing the required output paper size: Long Edge Feed (LEF) Letter (216 x 279 mm / 8.5 x 11 in.) or Long Edge Feed (LEF) A4 (210 x 297 mm / 8.3 x 11.7 in.).
    4. Select [2 > 2 Sided] button.
    5. Select the [Layout Adjustment] tab.
    6. Select the [Original Size] button.
    7. Select the [Preset Scan Areas] button.
    8. Select a paper size that is half of the size of the output paper selected in step 3. Make sure to use the opposite orientation: Short Edge Feed (SEF) Statement size (140 x 216 mm / 5.5 x 8.5 in.) or Short Edge Feed (SEF) A5 (148 x 210 mm / 5.8 x 8.3 in.).
    9. Select the [Save] button.
    10. Select the [Output Format] tab.
    11. Select the [Page Layout] button.
    12. Select the [Pages Per Side] button.
    13. Select the [2 Pages] button.
    14. Select the [Save] button.
    15. Select the [Job Assembly] tab.
    16. Select the [Save Current Settings] button.
    17. Under the Setting menu, select an available slot.
    18. In the Setting Name text box, enter a name, such as ID Card Copy
    19. Select the [Save] button.
    20. Make a copy using one-button access. See the Related Items below for additional information
    • lelix2603
      Minutes
      Thanks!!!Great solution!
