Docucolor240 calibration
  • funcom
    • Aug 2009
    • 28
    I had replace ros yellow/Magenta. How to make calibration?
  • azehnali
    • Nov 2009
    • 679
    Re: Docucolor240 calibration
    what are you trying to calibrate
    the copier or fiery??
    • adriansto
      • 2388
      Registration control setup but only it is necessary.
      • kalindd
        • Jun 2008
        • 192
        Run DC675.
        That is the only adjustment you need to do.
        Good luck.
        • funcom
          • Aug 2009
          • 28
          How to change values of registration setup.
          Can you explain?
          • funcom
            • Aug 2009
            • 28
            i processed dc675 but color registration is in the same configuration
            Please help?
            • kalindd
              • Jun 2008
              • 192
              What do you mean?
              Even after Dc675, none of the numbers are changing?
              If that's so, DC675 was no completed with success.
              Are all 4 colors printed with good density?
              Why you have changed the ROS in the first place? Was there a problem with it? What kind?
              • funcom
                • Aug 2009
                • 28
                all colors are correct but yellow no.
                dc675 complete sucess
                • kalindd
                  • Jun 2008
                  • 192
                  So yellow has no good density or yellow is misregistered?
                  see here http://www.copytechnet.com/forums/xe...tml#post238040
