XEROX 7665 firewire communication error
  • emcreklam
    • Sep 2008
    • 9
    Hello
    Here is a problem if you can help!!!!
    The software loads with the yellow square going right to left ' the square turn red then green and stationary for 2 minutes and then i get the " Firewire communication with the copy controler occurred ". Anyone can help on this matter?
    Thanks!!!!!!!!!!
  • JustManuals
    • Jan 2006
    • 9838
    Re: XEROX 7665 firewire communication error
    Paul@justmanuals.com
    • adriansto
      • 2373
      What version of firmware do you have on machine:
      40.032.xxxxx or 40.033.xxxxx ?
      Can you see an code error ?
      • emcreklam
        • Sep 2008
        • 9
        I cant see code error. My firmware version 040.033.52800
        • adriansto
          • 2373
          If you have scanning options then remove the scan cable between net controller and CCM and see if error message is changed. Also you can remove scan board from inside of net controller.
          • emcreklam
            • Sep 2008
            • 9
            Thanks for your help. I tried to remove the scanner cable, but error message is the same
            • Milo Wilson
              • 498
              Means the controller boots completely but does not sync with the rest of machine. Pull the fire wire cards on both ends of cable, clean contacts and put back in and reboot. Could have a bad firewire cable or firewire card.
              • vinil
                Re: XEROX 7665 firewire communication error for Wc7665.
                the machine is starting and restatring by itself. could any one help me with this problem
