WC4250 - Light Image problem
  • kurtray
    • Nov 2011
    • 7
    [Misc] WC4250 - Light Image problem
    Customer has a WC4250 *just* out of warranty (of course), and they've had a creeping problem with images getting lighter.
    Ran through the IQ7 Light Image RAP:
    - Happens with both copies and prints, so it's not CCD
    - Verified toner and drum don't have any extraneous packaging material
    - Cleaned LSU window, but it was pretty clean to start with
    No real difference in output as a result.
    From here, it looks like it gets expensive: replace LSU, replace HVPS, replace side cover assembly, replace ambient temperature sensor, etc...
    Looking for suggestions to nail down source of problem without buying a bunch of expensive parts to test it out!
    Thanks,
    Kurt
  • livewire
    • Sep 2011
    • 608
    Re: WC4250 - Light Image problem
    The problem may be in Drum Cartidge, Transfer roll (BTR) or Main PWB. Try also with Firmware Updete using CentreWare Internet Services (CWIS). Default Name is "admin", default password is "1111". Information is available in System Administration Guide: http://download.support.xerox.com/pu.../en/SAG_EN.pdf
    • kurtray
      • Nov 2011
      • 7
      The problem was indeed resolved with a new drum cartridge.
      Thanks!
      Kurt
