Adjust 5745 ppm??
  • Brandonpbm
    • Sep 2025
    Adjust 5745 ppm??
    Hello. Does anyone have any information on how to adjust the ppm of a WC5745?
  • seansbar
    • Dec 2010
    • 198
    Re: Adjust 5745 ppm??
    Sure, I'll have one of the sales people call you for an upgrade.
    • ZeusGT
      • 271
      LOL!!! Yeah, after you get him to upgrade, sell me the 5745. Seriously though, I don't believe that you can change the PPM of a machine unless you change A LOT of expensive gear.
      CompTia A+ Certified
      CompTia Net+ Certified
      CompTia Server+ Certified
      CompTia Project+ Certified
      OP Scanshare Certified
      • Brandonpbm
        I know how to adjust the 5600 series but the password for the run control 03-012 is different on these new machines. The internal components for the 5745 and 5755 are identical. The only difference is the value of the 03-012 Prod Config (Speed).
        • ZeusGT
          • 271
          Really? I have several 5638's here. What do I need to do to increase the PPM of these machines? Thanks
          • JustManuals
            • Jan 2006
            • 9838
            If we told you how, we'd have to kill you too.
            • ZeusGT
              • 271
              Hahaha... Nice!
              No seriously, how do you do that on 56xx series machines without swapping logic and parts?
              • seansbar
                • Dec 2010
                • 198
                There are a few (not just the one mentioned previous) password protected NVM values that can can be changed to make the machine think it is a different speed. If you look long enough in SearchLite and eDocs you will be able to figure it out. It is dubious that is will even speed up the machine.
                I once took a network controller off a 5665 and put it on a 5638, I knew I should have alt boot it, but wanted to see what would happen..... Well it made the 5638 think it was a 5665. Had error after error, it didn't like the fuser or the drum. Would not fully boot. It was a mess. Had to reset several NVM values to the correct value, and then alt boot the controller, like I should have in the beginning. What a waste of 2 hours. Never do that again!
                I believe if you want a faster machine, buy one!
                • Yasser Samy
                  hi, I need the pass code to change the 5755 PPM , I changed NVM from 5745 to another copier 5755 ,so, I need the password to change diagnostic 131-loc 8-1
                  please help me,,,,thanks Yasser
