DC250 error code 042-328 how to fix it
  • afropro
    • May 2012
    • 61
    I have this problem is there any solution for it the code error is 042-328
  • bojans
    • 1313
    Re: DC250 error code 042-328 how to fix it
    42-328 - Belt Edge Sensor Failure
    You should clean IBT belt module, probably rolls contaminated with toner.
    Reset NVM location 741-105 to 0
    Run Belt Edge Learn. You can use UI diagnostics (DC956).
    • afropro
      • May 2012
      • 61
      Do you have any pic how i can remove the belt module so i can clean it, cuz i am new to this, and the NWM does it have to be reset in the printer monitor or is it specific software that lets you modify nwm.
      By the way I have another question, I have posted here but no one seems to help me, my Fiery exp250, is freezing, I have posted a pic where it freezes you can have a look at it, maybe you can tell where is the problem, when i connect it with monitor win xp starts normal, but i cannot print because it stays ad Fiery 6 logo in the small monitor in Fiery rip.
      Thanx.
      link http://www.copytechnet.com/forums/xe...stem-logo.html
      • bojans
        • 1313
        Thanx.
        With so many problems, what you need is a xerox tech!
        I gave you solution, but can't teach you how to fix it.
        • adriansto
          • 2383
          Thanx.
          If this is your machine and you want to selfservice it then you need service manual and pws tool for it.
          In service manual you have a presentation how the machine works
