Color scan on Xerox 5775
  • jeanpaul
    • Mar 2009
    • 117
    [Misc] Color scan on Xerox 5775
    Hi to All,
    Does anyone know the pin code to enable color scan on WC5775?
    Thanks & Rgds
    JP
  • fogra27
    • Mar 2011
    • 29
    Re: Color scan on Xerox 5775
    - it is a hardware option you need a boar and a cable between SIP and NC.
    And the PIN is
    Scaning Kit A: 23100800 B: 42897946
    BB
    • jeanpaul
      • Mar 2009
      • 117
      And the PIN is
      BB
      Hi & thanks for your reply.
      The 5775 is using a Single Board Controller (SBC) which is under the scanner and according to Xerox
      a colour scanner comes equipped with these models (5765,5775,5790); however, in order to use the scanner, A PIN number is provided and must be entered at the printer in order to use the colour scanning feature.
      • eurekawins
        • Mar 2011
        • 5
        And the PIN is
        BB
        Gud evening sir! Can you pls provide me the activation code for "SPEED ID MISMATCH" Thanks.
