Xerox c6550i blur line on cyan
  • brianho80
    • Sep 2009
    • 198
    Hi expert,
    My xerox c6550i has a 2-3mm blur line (not solid) when printing single cyan color,however test on
    magenta, yellow and black do not have such issue.
    Tried to swap the color drum, blur line remain there. Check developer tank and try clean up those dirty in DV tank but remain same.
    What should i do next ??
  • bojans
    • 1313
    Re: Xerox c6550i blur line on cyan
    If it's not dirt in developer, then it's dirty laser.
    • brianho80
      • Sep 2009
      • 198
      Do you think try replace the Dv tank first??
      I just did another service clean up the laser mirror from
      Inside machine, we can see the mirror above drum unit.
      Problem remain same..😓
      • bojans
        • 1313
        If you have clogged toner inside developer tank, you can see line on it by turning developer with hand.
        I usually remove laser from machine and clean all mirrors. What you see from inside is protective glass. It should be cleaned from both sides too.
        Please post picture with cyan 20-30%
        Problem remain same..
        • brianho80
          • Sep 2009
          • 198
          Hi Bojans,
          here i attach the sample for your reference.
          are you able to see the blur line??
          • brianho80
            • Sep 2009
            • 198
            Does anyone know how to dismantle laser unit??
            • bojans
              • 1313
              Check PM
