Error Code 124-702 in large print jobs - Workcentre 74xx
  • leoace
    • Jan 2012
    • 12
    [Error Code] Error Code 124-702 in large print jobs - Workcentre 74xx
    Hi everyone,
    our customer is experiencing "random" 124- 702 Errors (output destination was changed by user) while printing large PDF Docs (2000 pages +) via webinterface (not printing via Xerox Drivers).
    The Machine(s) WC 7435 both just switch from finisher output to inner output and disable the finisher for further print jobs,
    but the finisher can still be used for copying. Ive been told that sometimes there appears a 024 Error right before the machine
    switch the output destination.
    This problem appears on both 7435, one with newest Firmware, one with an older one.
    I guess its a command in the document which cause that error, but i can not reproduce that error by printing via web or Xerox Global Driver via Notebook / crossover cable.
    I usually just clear the error log and restart machine, so the user(s) can print to finisher again until that error appears again. Due the larg ammout of documents / print jobs its hard to say
    which user or file cause that problem. The administrator told me he tried to print the same PDF File again after that error / system restart and printing went well without errors.
    Anyone ever seen / heared of that problem? Im currently seeking in eureka, but no real promising hints so far...
    thanks
  • xeroxsharp
    • Nov 2008
    • 270
    Re: Error Code 124-702 in large print jobs - Workcentre 74xx
    Maybe you could try,that every computer use a driver which is compatible for his operating system,not printing via server driver.
    I already had this code (024-...) in xerox 7120 when client try to print a big file and try to use server driver.
    • leoace
      • Jan 2012
      • 12
      I think that this (024-xxx) is a problem of driver/driver configuration/PS DIMM.
      Could you describe that more precise please? Driver is not used due direct Printing via Machine Web Interface. But i really have no idea because common print jobs, even in larger size (eg. office, SAP ect) work. That error appears random, strange thing is that - if you restart the machine - the second time you print the same file via web it works without any trouble...
      i will check that tomorrow at customers place. Usually they all print via server based WC74x PS drivers, but in that case the large job was sent directly to machine...
      I just wonder why two almost identical machines (firmware different) show up the same random error without any clear reason...
