510dp wide f
  • walidcharifi
    • Feb 2011
    • 379
    510dp wide f
    Hello,
    I have a printer Xerox 510DP plan but I do not know how fair it is periodic maintenanceand the elements that need cleaning machines help me please
    and how to make a counter cleaning machines
    ---- How to make the toner linear meter?
    thank you
  • ZeusGT
    • 271
    Re: 510dp wide f
    Lmao! This wide format is going to eat your lunch if you have never worked on one of these before. Clean the detact and the charge grid CAREFULLY or you will end up causing more problems. Be watchful of the developer seals being that they always prematurely fail and cause problems in the detact housings.
    I don't understand the other questions, but do yourself a huge favor and get a service manual. You will be using a lot of the chain commands to check the maintenance counters. Best regards
    CompTia A+ Certified
    CompTia Net+ Certified
    CompTia Server+ Certified
    CompTia Project+ Certified
    OP Scanshare Certified
