Synergix Scan System - initialization fail
  • Estico
    • Jun 2012
    • 21
    [Error Code] Synergix Scan System - initialization fail
    initialization fail with no error code - does anyone know what is the issue? thanks.
  • adriansto
    • 2384
    Re: Synergix Scan System - initialization fail
    Do you have service manual ?
    • Estico
      • Jun 2012
      • 21
      i have the service manual but there is no code on the screen so not sure what to look for...
      • adriansto
        • 2384
        Try to see where the problem is. Power on the controller, then try to power on the printer and see if you can get into service mode, remove the cables from scanner and see if the lamp go on at power on ,etc. Read with attention the service manual.
        • Estico
          • Jun 2012
          • 21
          The controller is working fine, i can print to it no problem... It is the scanner not working and because of the "initialization fail" error can't really get into service mode.
          • adriansto
            • 2384
            Probably lamp ballast pwb (pl1.4 - nr.10 ) is gone.
            Check it and replace .
            • Estico
              • Jun 2012
              • 21
              the lamp goes on when power on... Any other thoughts? Thanks again.
              • adriansto
                • 2384
                The exposure lamp should power off after Post 6 but this one remained on and stopped on Post "A".
                Can try to do GP14 from sm
                I think DDS = ON on accxes printer configuration settings !
