xerox wc 7242 color off last 2 inches
  • Bri Ski
    • 48
    on an 11x17 print from top to bottom the first 14 1/2 inches is perfect. The last 2 1/2 inches the color is way off. It appears it is dropping the yellow from the print and is a hue of red. For example the words "dream stone" are yellow all the way to this point then they are redish. its not just the words but the whole image from left to right at the bottom 2 1/2inches of the 17 inch print. as if the yellow is not there anymore but reddish. I have swapped yellow dv unit, transfer belt and transfer roller and the drum. when i swapped each part the first print out was fine all the way then prints after that look reddish and no yellow. It is not dumping any toner or streaking, no dots of toner. just an off color image at that point. thanks for any help. I havent swapped the magenta dv unit, but it looks like its lacking yellow not over doing red. and its never anywhere else accept the last two and a half inches of a 17 inch sheet. Thanks again
  • adriansto
    • 2384
    Re: xerox wc 7242 color off last 2 inches
    Open and cheat the left door, do a print and see how the print looks on IBT belt. You can stop the machine remove IBT and inspect the whole image.
