xerox wc 7335 touch panel
  • johnner66
    • Mar 2009
    • 265
    anyone out there where can i buy the touch panel for the 7335 thanks everyone
  • bojans
    • 1309
    Re: xerox wc 7335 touch panel
    Try with partsdrop.
    • mrizer
      • Mar 2009
      • 70
      We have them new and on exchange. Part number is 848K19761 or 848K19761-EX.
      Michael Rizer
      Free Technical Support
      Item Inc. 800-367-4836
      mrizer@iteminc.com
      • Exok
        • Jun 2011
        • 750
        If its just the touch screen you need. Do a search for this part # N010-0554-T504.
        I use these touch screens as a replacement for all WC 73xx machines as well as 4595.
        • kamoro
          • Feb 2011
          • 21
          Originally posted by Exok
          If its just the touch screen you need. Do a search for this part # N010-0554-T504.I use these touch screens as a replacement for all WC 73xx machines as well as 4595.
          Hi,
          I've noticed that, according to fujitsu tech spec, the touch screen you describe (N010-0554-T504) has the flat located on the left side but in the middle and not a few centimetres from the top as I can see in the one of my Xerox 7345 Touch_Screen.JPG..
          Is it possible to use it the same? Do I need to do some particular action before or after installation?
          Many thanks and kind regards,
          Fabrizio
          • Exok
            • Jun 2011
            • 750
            N010-0554-T504 has worked in every WC7328 - WC7346 I've ever serviced. I don't recall if the ribbon cable was in the center or closer to the top. I don't see why it would be in a different place for you than it is for me though.
            • kamoro
              • Feb 2011
              • 21
              Ok I'm going to try... any particular operation before changing it?Only calibrating with 0,1,3 holded during switch on?Thanks
              • Exok
                • Jun 2011
                • 750
                Yes, that's the only calibration needed.
                • kamoro
                  • Feb 2011
                  • 21
                  Yeeeesssssssss!!!!!!!!!
                  It works perfectly!!!! wonderful...
                  Many thanks I save a lot of money...
                  I have bought the touchscreen here, (very very very fast shipping and good price..) and the only difference between the one in the machine and this, is that it's a bit thinner, anyway it fits perfectly.
                  For instance, the touchscreen has the ribbon cable not in the middle of the left side, has described in the technical drawings, but closer to top (as the original)
                  I take 20 minutes to change the touchscreen..
                  Thanks a lot again...
                  • djwhoo
                    • Aug 2013
                    • 117
                    good job
                    • max2013
                      • Mar 2013
                      • 54
                      where you buy the youch screen and what is the price you paid for that thanks...
                      • FBM
                        Originally posted by djwhoo
                        good job
                        Xerox WorkCentre 7228 7235 7245 7328 7335 7345 7346 7428 7435 Touch Panel Screen | eBay
                        this will be the best price.
                        • bmt_hr
                          • Mar 2011
                          • 119
                          I buy from this company. Look attachment.
                          14$
                          proforma.pdf
                          • FBM
                            14$
                            [ATTACH]24870[/ATTACH]
                            Yeah, you bought it from China...with expensive shpiping.
                            it's not just $14. you risk the quality of the panel, and how about the warranty of the panel?
                            I will not risk my money unless the seller is in US.
                            • bmt_hr
                              • Mar 2011
                              • 119
                              They work for now . The shipping is expensive but they arrived quickly.
