Do I really need a PWS to work on Xerox copiers?
  • ZeusGT
    • 271
    Hello all!
    I have been repairing Xerox copiers for a little while now and I have read on these forums that you really need a PWS to perform a lot of the repairs on most of the Xerox equipment. I worked on a Docucolor 240 with a persistent 042-326. I read in many different forums on the web and the general consensuses is that you could only fix the unit with a PWS because the fault occurred over 5 times and there is only a 3 time recurrence threshold.
    Long story short, I was able to make the necessary repairs and reset the NVM Chain without using the PWS by going into the service mode. From what I researched on the machine, same could be done for resetting the fuser faults too.
    My question is, why would I need a PWS on this machine or say for instance the Workcentre 5675? Thanks for your feedback.
    CompTia A+ Certified
    CompTia Net+ Certified
    CompTia Server+ Certified
    CompTia Project+ Certified
    OP Scanshare Certified
  • adriansto
    • 2392
    Re: Do I really need a PWS to work on Xerox copiers?
    The pws is a tool and it help you to diagnose and repair the defects.
    Dc 240 has internal diagnostic builtin but some procedures needs pws tool because they missing from internal diagnostic. WC 56xx has complete diagnostic builtin but you need pws to reload software on hdd, to save and restore nvm's and so on.
    DC 2060, WCP3545 has no internal diagnostic. It exist only on pws tool.
    With pws you can use edocs and bulettins. More quickly and easily to use.
    • tech9
      • 216
      57xx you can altboot via usb stick. You would although need a PWS if it lost its NVM settings.
      The long and short of it if you really want to be the best of te best on Xerox kit the PWS is the answer a properly configured PWS has all the info/tools/tips/software to fix Xerox machines.
      • XeroxTechBrazil
        • Aug 2008
        • 199
        A proper PWS laptop will speed your service work, help you solve difficult to diagnose problems in all Xerox machines, and is a must in many. It will pay its investment back quickly, and then, many times over.
        The available PWS products vary greatly, and many techs don't understand this. The PWS is a combination of the PWS software, EDOCs, diagnostic tools, and SNAPS. These applications are supported by conventional software packages like Microsoft Office, Adobe Acrobat, video software and a variety of others. EDOCs are updated frequently, as are the SNAPS that drive SearchLite.
        Finally, you need some rock solid backup that you take with you so if something does go wrong on the road you can quickly and effortlessly restore the PWS to its original working condition.
        Please PM me if you are in the market for a PWS -before you purchase something you will be unhappy with later.
        • xtrain
          • Dec 2012
          • 233
          have complete pws laptop for sale. xtraininc@cableone.net
          • JR2ALTA
            • Feb 2010
            • 2033
            glad i don't work on that crap.
            • xtrain
              • Dec 2012
              • 233
              You do not need a PWS laptop unless you work on xerox machines made in the last 30 years. If you want to carry 100 pounds of paper service manuals, parts lists, and tech tips, a PWS is not needed. If you want to guess at the fix for a problem, dont use a PWS. If you dont want to link up with an electronic xerox to run diagnostics, ruitines, etc. , you dont need a PWS. If you think you may need a PWS after all, e-mail me for a special deal. xtraininc@cableone.net
              • xtrain
                • Dec 2012
                • 233
                I am glad you didnt too.
                • rcancino
                  I only need the gsn lock password mine has expired
                  • xtrain
                    • Dec 2012
                    • 233
                    I dont use GSN, I use PWS Lock, which is a non expire password.
                    • rcancino
                      where can I fiand the pws password?
                      • KHALEDGAD77
                        • Jan 2012
                        • 11
                        i have pws laptop it work for evernon expiriglock 2000 use khaledgad77@yahoo.com
                        • cws10
                          • Nov 2012
                          • 3
                          How can I go about getting a PWS?
                          • davidj7
                            • 1107
                            how can i get a screwdriver
                            a machine is only as good as your tech : source:screwtape ; the scary one
                            • xtrain
                              • Dec 2012
                              • 233
                              If you want to purchase a "portable work station" laptop, e-mail me at xtraininc@cableone.net. Let me know what Xerox products you want loaded.
