8825 DDS color
  • straffer
    • Jun 2025
    8825 DDS color
    Hi I have the xerox 8825DDS with the 7346 and want to know if it is capable of doing color scanning to pc with color feature key. I can't get confirmation from xerox. On this web page brochure is states it does. But does not specify which scanner model is with it. http://www.xerox.com/downloads/usa/e...s_Brochure.pdf Thanks.
  • xcopytech
    • Aug 2006
    • 1794
    Re: 8825 DDS color
    7346 scanner only can scan B&W.
    You need synergix scanner for color scanning
    • straffer
      Re: 8825 DDS color
      The 8825 is synergix. stamped on the machine. What model of scanner would be color.
      • adriansto
        • 2384
        Re: 8825 DDS color
        Synergix is the name of scanner and is different from X7346 / 7356.
        And for the whole group - scanner, controller, printer - the name is synergix system in place of DDS system
        • livewire
          • Sep 2011
          • 608
          Re: 8825 DDS color
          Very complicated affair.
          The brochure that you have provided written that Color Scan-To-Net is Options.
          In presenting the 8825DDS, 7356 is set for user interface.
          I found no information on this Color Scan-To-Net kit.
          I do not know whether it is just enablement code or are there hardware and enablement code.
          Here is some information from me.
          I hope this is helpful.
          Xerox 8825DDS* have N5T or EV4 Controller.
          What is your controller?
          Color Scan-To-Net (JPEG/TIFF) is Options.
          Print a Printer Configuration.
          Printer: 8825DDS
          Scanner: 7346
          Controller: N5T with TAG 3**
          High Density Centronics Cable - 162K32730
          Controller Accessories: EPS = External Print Server - 160K54930
          IEEE 1394 PWBA = enable connectivity to the interceptor scanner - 160K79060
          *DDS = Digital Document System or Digital Engineering System
          **TAG 3 = Enables PLI N5T w/Tag 3 Release
          Controller: EV4*
          Controller Accessories: SCSI** PWBA = enable connectivity to the 7346/7356 scanner - 160K80670
          VPI PWBA = 160K63670
          *EV4 = High Density Centronics Cable (Not Spared)
          **SCSI = Small Computer Systems Interface
          Input Ports: Serial = One host serial port and one debug serial port
          Parallel = IEEE 1284 High density Centronics connector
          SCSI = SCSI-2 Connector, SCSI-3 Optional on EV4
          VPI = 37 pin D connector, differential only
          Ethernet = N5T (with and without Tag 3) and EV4
