WorkCenter 4150 No Power
  • copylaser
    • 53
    I have power at the power supply but no 24dc or any other signs of life.
    Any suggestions?
  • mrizer
    • Mar 2009
    • 70
    Re: WorkCenter 4150 No Power
    Most likely the Power Supply/SMPS #1, which is 105N02091, but could also be SMPS #2, 112N00220, although I haven't really seen this one fail.
    Michael Rizer
    Free Technical Support
    Item Inc. 800-367-4836
    mrizer@iteminc.com
    • copylaser
      • 53
      I dont have a circuit diag but I do have dc and ac at the power boards. Is there a safety switch that powers down the operation panel?
      • mrizer
        • Mar 2009
        • 70
        There are 24V interlock switches on the machine for doors, but that shouldn't affect the control panel. Are any of the fans running?
        Michael Rizer
        mrizer@iteminc.com
        • copylaser
          • 53
          I have no fans I do have some DC voltage from the boards
          • impaqsol
            • Jun 2009
            • 87
            Re: how to disable WorkCenter 4150 Finisher Option
            I have a Xerox 4150 with finisher, but I don't have the exit tray for the finisher. I would like the exit tray ( NEED PART NUMBER) and where to buy or if not how to disable the finisher option on this copier.
            Please need help on this.
            Thxs.
            • mrizer
              • Mar 2009
              • 70
              The part number is 050N00489 and we have it available here: 050n00489 xerox wc4150 stacker tray-finisher item inc
              Michael Rizer
              mrizer@iteminc.com
              • copylaser
                • 53
                Do you have a part # for the operation panel
                • mrizer
                  • Mar 2009
                  • 70
                  Part number 002N02621 is for the whole control panel, and 123N00244 is just the LCD.
                  002N02621 - 002n02621 xerox wc4150 control panel item inc
                  123N00244 - 123n00244 xerox wc4150 lcd touch screen item inc
                  Michael Rizer
                  mrizer@iteminc.com
                  • copylaser
                    • 53
                    The energy saver light in not on either. You think it a be the whole op panel?
                    • mrizer
                      • Mar 2009
                      • 70
                      I think your op panel is fine. Your power supply is bad. If your op panel was bad, your fans would still be running.
                      Michael Rizer
                      mrizer@iteminc.com
