WC - 7232 Transfer Belt
  • benerin
    • Dec 2011
    • 59
    [Misc] WC - 7232 Transfer Belt
    Hello Everybody...
    I Replaced transfer belt on Work Centre 7232, due to message coming "Transfer Belt needs to be replaced", after i replaced new belt. same message coming...
    somebody can help me to finish this problem!! I don't know how to reset the counter of IBT Belt..
    Thanks a lot..
    Benerin..
  • bojans
    • 1309
    Re: WC - 7232 Transfer Belt
    Originally posted by benerin
    Hello Everybody...
    Thanks a lot..
    Benerin..
    This is for wc 7328,7335,7345,7346 series. I'm not sure if it's the same procedure, but you can try.
    Entering Diagnostic mode (CE Diagnostic Mode):
    Hold ‘0’ for at least 10 seconds, then press ‘Start’… a password prompt should show up. Enter ‘6789’ followed by ‘Confirm’. Now press the ‘Machine Status’ button.
    Resetting Counters:
    For these models, you will need to get into the “UI Diagnostic Mode” as explained above. Once you are in the Tools tab, choose the following from left to right: System Settings, Common Service Settings, and then in the right column, scroll down and touch “Maintenance / Diagnostics”. Scroll down and touch the button for “Adjustment / Others”.
    There you’ll find two choices: ‘Machine ID / Billing’ and ‘HFSI Counters’. Touch the ‘HFSI Counters’ button (High Frequency Service Items). Here you’ll be prompted to enter a “Chain-link” number, so enter the appropriate number from this list:
    1. 954-801 = IBT Belt (Transfer Belt)
    2. 954-802 = 2nd BTR (Transfer Roll)
    3. 954-803 = IBT Cleaner (Transfer Belt Cleaner Assembly)
    4. 954-804 = Fuser Module
    Then press ‘Confirm’ and some data shows up, including the current count on the part in question. If you then touch “Reset Current Value” the machine will go to a confirmation screen where you need to touch ‘Reset’.
    Good luck
    • xeroxsharp
      • Nov 2008
      • 270
      xerox 7132/7232
      954-824 ibt belt counter
      954-825 ibt cleaner counter
      954-826 2nd btr counter
      954-842 fuser counter
      br
      • benerin
        • Dec 2011
        • 59
        Thank you very much BOJANS & XEROXSHARP on your reply.. I'm for sure it will give me a big help for me your advances.
        Thank you again and GOD BLESS you BOTH...
        Benerin
